Hi,
I have a lot of SVCD's that I want to burn on DVDs. I use TMPGenc DVD Author and when I load my SVCDs, lot of them give me this error message The video GOP is too long.
I tried to reconvert my files with TMPGenc but the quality of the file is bad.
Could someone help me to fix this problem please ?
TIA.
Nipal
It is not advised to burn SVCD content to a DVD because the SVCD resolution of 480x480/576 is not a compliant DVD resolution.
There are some tricks that will make it work on some DVD players but most will not function correctly.
You might want to try re-encoding them with TMPGEnc using 352x480/576 and do a CBR of 4000kbps to 5000kbps for best quality conversion although yes some quality will be lost.
I have been using SVCD2DVD and using TMPGEnc DVD Author for the authoring and it always says the GOP's are too long. I ignore it and they play fine.
Thx for your answer redwudz, I ignored the error message as you suggest and it works ok on my DVD player.
Sometimes the solution is too simple
Thx also FulciLives.
Nipal
DVD video has Too Long GOP, What To Do
By Brent212 in forum Authoring (DVD)Replies: 5Last Post: 14th Aug 2013, 09:36 -
Best video format for long term compatibility?
By mart0224 in forum Video ConversionReplies: 11Last Post: 20th Sep 2008, 23:39 -
Long term storage of home video.
By kreg in forum Newbie / General discussionsReplies: 7Last Post: 6th Jul 2008, 04:50 -
ES Video and GOP timecode
By arturo83 in forum DVB / IPTVReplies: 8Last Post: 21st Aug 2007, 07:57 -
VCD to DVD (TDA error: GOP too long)
By jelir in forum Authoring (DVD)Replies: 1Last Post: 6th Jun 2007, 10:40
