  1. The software generates this error when tring to burn VCD.
    I installed the demo version of Nero and was able to burn a VCD with no problems.
    Any thoughts on what is causing the snag with the Adaptec product.
  2. dont use Roxio or Adaptec
    support Nero - Roxio is too LIMITED
  3. Dear Stinky,
    Thank you for your opinion, however that does not solve my problem.
    Regards,
    ToonTown
  4. Dear ToonTown,
    Roxio is too limited - if your VCD differs even slightly from 'their' standard you have an un-fixable problem.
    No matter of hard work will get Roxio to burn it - you already found the solution, go with better VCD software - Nero.
    It wasn't my opinion but the answer you had already found
    -stinky
