I have some Super 8 movies currently on VCD. They have video & no sound.
I pulled the MPEGS off the disks using VCDEasy.
Used SVCD2DVDMPG 1.1.1.16608 to convert from VCD to DVD-VCD. Settings used: VCD, mpg --> ES, Hor Res patch 352 Entire file. Everything seems to look OK at this point after processing. Processed both video & audio even though there is no sound.
Files accepted into Pinnacle Impression Pro 2.2.1 as ES assets OK.
Set up chapter stops, OK.
Go to build DVD. Select Create UDF Image only. Goes to process and the error is "MUX : INVALID VIDEO ERROR".
I assume that the program can't mux the ES back together. Not sure though if it a SVCD2DVDMPG problem or a Impression Pro problem.
I have processed SVCD of home movies with success using the same process.
Anybody have any ideas about this problem. If necessary I may have to capture from original VHS tape in DVD format to solve problem. But wanted to avoid that if necessary.
Thanks in advance!
Results 1 to 1 of 1
MovieWatcher666
Home movie dvds to pc conversion
By slimmx in forum DVD RippingReplies: 2Last Post: 27th Jan 2011, 08:28 -
home movie film conversion recommendations?
By spiritgumm in forum Off topicReplies: 0Last Post: 6th Nov 2010, 10:04 -
Home Movie conversion help
By franksvideos in forum Newbie / General discussionsReplies: 2Last Post: 1st Apr 2010, 10:36 -
Home movie / Movie Creation Software
By ironape2 in forum EditingReplies: 3Last Post: 3rd Apr 2009, 09:28 -
Home movie conversion - am I missing any info before I commit?
By Hawks in forum Capturing and VCRReplies: 15Last Post: 24th Jan 2008, 05:32
