  1. i got 10 mpgs file all with the same bitrate etc,how can i join them together to 1 file ,can i do this with virtualdub or is it with avi ,does somebody know a programm and how ,thx
    USA
    TMPGEnc can do it with the 'merge' function.
  3. 1st : VDub is for avi
    as was said TMPGEnc will work, and if you're dealing with MPG2 it is probably the best considering it's "price"
    for mpg1, Boilsoft's EZ Merge works well (and joins plenty of other file types as well), but it is not free. Same with VCDCutter
    Camel's MPEG Join will work on mpg1 and it is free...you'll find it here:
    http://abmefaq.net/
  4. There are many outstanding guides in the forum.
