i am looking to by a new machine with the sole purpose of copying dvds.....i will not use the machine for anything else...no internet / no office stuff solely dvd recording....i am looking a t a base unit with 256mb, 40gb harddrive and a 2400 AMD processor......will this allow me to copy dvds ok......note the dvs i am copying are not official releases just homemade camcorder stuff i need to distribute to family members so i just need to make exact copies
If you want to capture video from a camcorder, then edit, render to mpeg, and then author and get it ready for burning on DVD media, then this system would struggle. I suggest at least 512MB of RAM. Also use the 40GB HD for the operating system and your other software. Use a second hard drive with minimum 80GB capacity for your video files.
I would suggest a more powerful CPU as well as a min of 512 Mb Ram. Maybe a P4 3.0 Ghz? (if i am not mistaken prices have dropped lately).
Video encoding-processing is a CPU intensive task.
Good Luck!
LeoNapierThe Truth Is Out There - X Files -
i will only be using the pc to copy the original dvd....i use my standalone to make the original but i then just want to burn copies......do i still need something with 80gb and 512mb....i am just making copies from a dvd disc not using the pc to capture........
If you are only going to be using yr pc for copying then, min specs will be more than sufficient!
I have an old Celeron 650, 192 Mb Ram laptop and it burns just fine with an external firewire Pioneer A-06. A 40 Gb HDD would be OK too.
Buying a new BD/DVD player - What should I buy?
By BobLoblaw in forum Newbie / General discussionsReplies: 7Last Post: 19th Oct 2011, 22:10 -
Looking for advice on buying a new DVD recorder
By luvsufo in forum DVD & Blu-ray RecordersReplies: 4Last Post: 16th Feb 2011, 16:10 -
Buying DVD DL on Rima, need advice
By Thadius856 in forum MediaReplies: 1Last Post: 26th Jun 2008, 01:58 -
Buying a new dvd player soon, please recommend one
By dimmy32 in forum DVD & Blu-ray PlayersReplies: 6Last Post: 6th Dec 2007, 13:57 -
key things to look for when buying a dvd writer
By zinc in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Aug 2007, 11:50
