  1. If I use TMPGEnc to convert my .avi files to .mpg files, what do I do with the .wav file created. I know I can use different authoring apps to create the video_ts folder, but in none of them can I find a place to select an audio source.
    Thanks in advance.
    Apr 2002
    The State of Frustration
    You can convert it to an .mp2 file using TMPGEnc, then change the extension to. .mpa. You can then demux the MPEG file to a .m2v and .mp2 files. Open IfoEdit and select DVD Author-->Author new DVD.
    Load the m2v file into video, and the mpa file into audio. Select the target directory and OK. The directory now contains the authored files your burner files.
    Hello.
