I've made 2 dvdmpg (2 different movies) and tried to author and burn them with TMPGE DVDAuthor. It turns out that one of them is PAL and the other NTSC movie and that they can't be burned on the same dvd-r. Is there any way to convert NTSC to PAL or can they actually be burned on the same dvd-r but not with this author or any other solution witch would result in one dvd-r containing both movies.
Thank you for your help.
I've done it before but you can't do it with TMPGEnc DVD Author. Your DVD will have no menu THIS way but....the latest versions of DVDShrink can do it(both NTSC and PAL on one disc). Rip one DVD to the HD and place one in the DVD-Rom and reauthor away via the DVD Browser in Shrink.
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 21:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 12:30
