I have some mpeg1 files (Karaoke .dat ), and I want to make a DVD, which can have hundreds of mpeg1 file and play in my dvd player. The main reason I want to do this is "NO NEED TO CHANGE DISKS".
I thought you can only use mpeg2 to make a DVD, and I don't want to convert mpeg1 to mpeg2. Anyone did something similar before? Is there any special software I need to do this?
Thanks a lot for the help.
most players these days can handle mpeg1 in addition to mpeg2
i have an apex 5131 and i know for a fact it plays mpeg1 with mp2 audio dvd's i author
i bet it would do the same for you on your player. If you got the time, author the dvd and burn it to dvdrw and give it a test. -
Go to Lordsmurf.com = Convert and Edit = Converting to DVD MPEG
__Then click on "Convert VCD to DVD"
VCD's are MPEG1 so I believe this should work.
Also seen some other guides and posts in doing VCD to MPEG1.
I have tried some and they do work.
Help. What program to use to make avi files play on dvd player?
By xxxThiefxxx in forum Newbie / General discussionsReplies: 13Last Post: 30th Mar 2010, 18:09 -
Will a blu ray disk play on regular dvd player in 480 lines of resolution?
By donfm in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2009, 07:00 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 13:15 -
How to make DVD from avi file to play on dvd player on tv
By marjolein01 in forum MacReplies: 11Last Post: 3rd Jan 2008, 12:37 -
Trying to make a DVD play on windows MEdia Player
By WuTangDvD in forum Software PlayingReplies: 6Last Post: 23rd Oct 2007, 09:24
