well i used TMPGEnc Plus 2.5 to convert an *.mpg video file i have, after finding out what the right resolution and framerate for dvd movies is. then i opened up TMPGEnc dvd author 1.5 to add the mpg file to a project.. now the only error i get is:
"* A video sequence header is necessary for every GOP in a standard DVD.
The video header is incorrect.
A video sequence header is necessary for every GOP in a standard DVD."
how can i fix this? also, how do you convert a *.wmv to an mpeg? videotoolbox doesnt recognize wmv's, and tmpgenc plus wont even open them to convert... any help would be greatly appreciated![]()
Results 1 to 12 of 12
check this thread
https://www.videohelp.com/forum/viewtopic.php?t=209108&highlight= -
thanks andie, setting the "Output interval of sequence header" from 0 to 1 solved the problem, and dvd author added it to the list
. now, can anyone help me out with how to convert asf\wma\wmv and quicktime movie files to mpeg? and in tmpgenc plus, whats the difference between the "ES"(Video + Audio) and "System"(Video + Audio) Stream types? becuase when i pick ES, it encodes the movie to 2 files, one for video and audio i guess... how do you put these together on a dvd compilation? thanks again
https://www.videohelp.com/download/MPEGSequenceMakerv02.zip
ES is elementary stream - video only.
most authoring programs will accept video+audio separate or
a system stream with both in one
If Vdub will open your WMV files , you can frameserve to TMPGenc
to re-encode into MPEG2 -
thanks, but i was trying to convert another file i had to mpeg, and my tmpgenc plus crashes(doesnt respond, then crashes)... is it cuz that video file is corrupt? because it only happens on that file.. what are good programs to repair videos?Originally Posted by FOO
bump, help with above question please... and what program can i use to convert and fix .wmv\asf\quicktime mov files?
You can use TMPGEnc to convert both wmv/asf and Quictime movies. For Quicktime, install the TMPGEnc Mov Plugin. Getting TMPGEnc to open asf/wmv is a lot more complicated. It doesn't always work the first time for a variety of reasons. Check out this thread:
https://www.videohelp.com/forum/viewtopic.php?t=208874 -
thanks, the quicktime plugin works... i'm still having a problem converting this wmv movie. firstly, i cant seek with windows media player(yeah, i got 9.0 and updated it with codecs and stuff). i used asftools 3.1 to enable the seek flag, but it still wont work. if i try to use dr divx or tmpgenc plus, the programs just crash. whats the problem and what tools can fix this?Originally Posted by teegee420
I'm afraid you are out of luck because it sounds like you have a corrupt file. I have yet to successfully repair a bad wmv file. As a last resort you can try converting to mpeg with Canopus Procoder. Sometimes it's less sensitive to problematic files than TMPGEnc.
hey, i fixed the seek problem. i simply converted the wmv to an avi, and it now works(seeks) perfectly. so this is basically the solution to anyone else who may be having the same problem 8).
Just caught up with this thread.Originally Posted by Cobra281
The behaviour of Tmpgenc, to appear locking up while opening the .wmv file is due to the fact that your particular file appears to be non-indexed. This is not an error but rather irritating.
Windows media files can be made seekable and un-seekable. The first is more appropriate for files you download and play while the second more appropriate for streaming media where every bit of overhead removed is welcome.
Another way to fix the unseekable file is to use ASFTools v.3.1 to re-encode the wmv file to become seekable. Then this (or such) files will be acceptable to Tmpgenc.The more I learn, the more I come to realize how little it is I know.
can't get ffmpeg to convert video to image sequence
By wiseant in forum Video ConversionReplies: 15Last Post: 12th Apr 2013, 08:37 -
DGindex "NO video sequence header found"
By JackDanielZ in forum Video ConversionReplies: 4Last Post: 28th Apr 2012, 08:41 -
AutoGK problem 'No video sequence header found'
By Sneblot in forum Video ConversionReplies: 2Last Post: 11th Jun 2011, 11:23 -
No sequence header on two vobs after authoring in Encore CS3
By Killer3737 in forum Authoring (DVD)Replies: 1Last Post: 7th Feb 2009, 07:30 -
VIDEO TS sequence
By red lion in forum EditingReplies: 1Last Post: 25th Jun 2007, 19:15
