  1. I am backing up my DVD collection (for travelling overseas). Mostly it works using DVD Backup (or OSEx 0.0101b) and then DVD2oneX 1.1.1... but I am having trouble with just one disc (Six Feet Under disc 3) which (a) does not work at all with OSEx (fatal error right at the start) and (b) is backed up okay with DVD Backup but approx. halfway through DVD2oneX process the app quits inexplicably. This is a brand new disc, but to make sure I rented 3 (that's three!) of the same disc, two of which were also brand new, and exactly the same thing happens with these. Curious how the other 3 discs in the series have not been a problem.... Can anyone shed light on this problem and offer a solution (so I don't have to bring the original with me), and/or is there another application like DVD2oneX that I should try? Thanks for the help!
    Apr 2003
    Have you ever tried "Mactheripper" yet?
  3. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    i remember discussoin of that dvd causing all sorts of problems
    try mac the ripper or yadex
    hopefully one of those will work for ya
    this rings a bell
  4. Originally Posted by galactica
    this rings a bell
    I didn't know there was on OSX version of Yade. Where can I get it?
  5. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Here is the official distribution page:
    http://www.macetvideo.com/yadex/dl_yade.html
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
  6. Member galactica's Avatar
    Jan 2003
    well yea that one works as well
  7. Thanks.
    It always seemed Yade grabbed higher quality stills than VLC and the finder screen capture.
