I have TMPGEnc to convert, then I am using Nero to burn. The problem that I am having is on the files to big for Nero (700,000kb+). So far I have tried HP Split, but that is apparently not the right program to use. What program should I be using to split the files? Specifically MPEG files (from the 'net).
Any help would be great.
If your files are VCD or SVCD compliant they'll fit just fine on a 700mb cd. You just need to use the VCD or SVCD compilation in Nero.
With Nero 7 Ultra, why are imported dvd files so big?
By wisny in forum EditingReplies: 13Last Post: 13th Mar 2011, 08:38 -
too big when burning with nero
By chief-1 in forum Newbie / General discussionsReplies: 14Last Post: 27th Aug 2010, 22:21 -
How do I keep DV files from splitting ?
By RWANDREWS in forum Capturing and VCRReplies: 3Last Post: 15th May 2010, 04:07 -
Splitting AOB files
By DeadSirius in forum Newbie / General discussionsReplies: 0Last Post: 23rd Dec 2008, 16:35 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 20:41
