  1. just like the topic says. i haven't seen this anywhere and couldn't find any options in the program.
    Dec 2003
    Just drag a song from you media pool onto the menu.
    Feb 2004
    Brisbane, Australia
    yes, just drag DVD compatabile sound onto the menu background. It will tell you if it is compatabile. I used the nero wave editor to quickly fix mine.
    As an extension of this question: How do you add sound effects to the menu selection buttons so the make a sound when you choose one?
    thanks
    Rommie
  4. thanks....ill try that.
  5. The DVD-lab website and the Help have examples.
