Hi im trying to convert my first dvd to dvdr i currectly have vob files and pdi files (seperate).
Im trying to convert these to a .img file i tried searching the forums and could only see convert help for .iso
Can any of you help me convert either the vob files to img or the pdi files to img
Thx
Darren
hey, arn't pdi files already images? oh well, why do u need to make an .img file? use imgtools to make an iso then burn with dvddecrypter. hopefully u have ifo files already? if not then u'll need to author the dvd, guides off to the left.
hope this helps, josh -
i have the ifo files yes already authored, i want img instead because i never have any problems with these files when ive had them on my pc before.
ive kept the pdi files just incase its easier to convert pdi to img instead of vob to img -
i am guessing you got those .pdi files from pinnacle InstantCopy.
Also they would be in the form .pdi1 .pdi2 so on and a .pdi (or something like that).
There is a little tiny software called "PDI2ISO". It converts all your pdi files into an iso file which can be burnt with ANY burning software. It does it relatively quick too.
Google search it and you should be able to find it. Or else, pm me and i will send it to you.
Cheers. -
I wouldn't do that. Sometimes Instant Copy doesn't do things exactly right...so you might want to check the DVD before burning it.Just save yourself the headache and burn the PDI with DVD Decrypter
You can download pdi2iso at:
http://www.mrbass.org/instantcopy/
Daemon Tools will let you watch the DVD from the ISO file. You can get it at www.doom9.net -
I apologize... I totally forgot about the program pdi2iso...Originally Posted by northcat_8
n00b question on format to use
By hbguru in forum Video ConversionReplies: 1Last Post: 28th Jan 2012, 15:08 -
n00b question about pc and hd cable
By NateDizzle in forum Capturing and VCRReplies: 10Last Post: 17th Mar 2011, 16:35 -
n00b looking for right section
By shiroshadows in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2009, 09:38 -
Ruby.framework (i'm a n00b)
By chrisssy in forum ffmpegX general discussionReplies: 1Last Post: 23rd Nov 2008, 23:17 -
n00b question (sorry!) re: installation
By pomoster in forum ffmpegX general discussionReplies: 2Last Post: 5th Feb 2008, 18:44
