Check it out
http://instorespecials.staples.com/staples/default.aspx?action=browsepagedetail&storei...pagenumber%3d3
Imation 25/pack is made by RicohJPN01, and it is really good, I burned over 75 and have no problem. It will be on sale starting 03/14-03/27 at www.staples.com or Staples store.
Remember first come fisrt serve, dont wait to loose your chance![]()
this has been the case with + media. have 2 more spindles to use up before buying more. great burns.Imation 25/pack is made by RicohJPN01
Hi,
I am sure because I bought 4 of 25 pack Imation last time at OM for $60.00, I came back and bought 4 more in different store, and make sure DVD+R 4X pack of 25 NOT 50 (50 are CMC for sure
). I am not sure about DVD-R because I did not buy it.
Here is the code
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID RICOHJPNR01
Format Capacity Not Formatted
Free Blocks 405405696
Free Capacity 4.38GB(4.70GB)
Book Type DVD+R
Media Type DVD+R
Media Id Code Speed 4.0x 5540KBps
Available Write Descriptor CLV 4.0x 5540KBps
Available Write Descriptor CLV 2.4x 3324KBps
Data area starting sector 30000h
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers -
Anyone know what the -Rs are? The Imation DVD-Rs I've gotten in the past have all been Ritek GO3s, which are quite satisfactory.
Pull! Bang! Darn!
Imation 4x DVD-RW problem?
By carbfrze in forum MediaReplies: 8Last Post: 11th Mar 2009, 16:31 -
Imation DVD Burner
By waituke in forum DVD & Blu-ray WritersReplies: 1Last Post: 17th Feb 2008, 16:34 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
Imation: Worst DVD Brand
By J C in forum MediaReplies: 4Last Post: 5th Nov 2007, 19:46 -
Imation DVD Writer problem?
By MAAG in forum DVD & Blu-ray WritersReplies: 3Last Post: 18th Jul 2007, 13:41
