I am having a problem with a DVD Rom Drive. The problem is, a few weeks, ago, I installed a DVD ripping program, that installed it's own drivers. Doing this caused problems, with the dvd drive. Now I can't play dvd disks. It will play audio cd's, but only in analog format. When I go to control panel, and click on Multimedia, then CD Music, digital playback is grayed out. The Drive I have is a "Mashita DVD Rom SR 8584A".
Problem 2, is I have an external Cd Burner, that since this problem, won't reconize the drive. so now, I can't make a 1 to 1 copy of a cd.
I've tried uninstalling the DVD Ripping program, Reinstalling Windows 98SE, unpluging, and pluging in the DVD Rom Drive, and Updating the ASPI Drivers.
When I check Device Manager, The DVD Rom Drive is listed under the CD Rom. the way it should be, but I am still having the same problem. I forgot to mention the DVD Rom is an OEM device. I would appreciate any help. Thanks in advance...
Results 1 to 1 of 1
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
DVD Rom speed problem
By dafoe in forum DVD & Blu-ray WritersReplies: 8Last Post: 26th May 2010, 11:06 -
CD \ DVD ROM not seen in Windows
By lacywest in forum ComputerReplies: 1Last Post: 16th Oct 2009, 09:19 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
dvd rom problem
By ieh4f in forum DVD & Blu-ray WritersReplies: 2Last Post: 13th Jun 2008, 02:49
