I went to the FAQ section, went to the Ripping section, clicked on "How do I rip a DVD to my harddrive?" and it went down in the page and I clicked on the applications link. I get the blue tool bar, then under it, it says:
Code:Warning: fopen(start.html): failed to open stream: No such file or directory in e:\vcdhelp\www\sefy\index.php on line 315 Warning: filesize(): Stat failed for start.html (errno=2 - No such file or directory) in e:\vcdhelp\www\sefy\index.php on line 316 Warning: fread(): supplied argument is not a valid stream resource in e:\vcdhelp\www\sefy\index.php on line 316 Warning: fclose(): supplied argument is not a valid stream resource in e:\vcdhelp\www\sefy\index.php on line 317
The faq section hasn't been updated in a few years, I may update it in some years...
. Use the how to sections instead, https://www.videohelp.com/dvdripping#6;34
I usually do use that section but I have an issue I thought the FAQ's might be poised better to answer. Thanks for the reply though, keep up the good work.
Baldrick, there seems to be some problem with the guide, but I haven't seen it happen on my page, and i'm really not an expert on HTML as you know
I'm working on 2.5 of the guide now, although a lot of updates, so i'm not sure if i'll be able to finish it this month, but i'll try! in the meantime those who have access problems can try my page although it will be slower:
http://sefy.iwarp.com/guides/index.htmlEmail me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Batch "file creation from a text file, Placed into a created directory
By Muther in forum ProgrammingReplies: 5Last Post: 24th Sep 2015, 18:29 -
Stylized "RW" logo found on blank media packaging - what does it mean?
By ibzomie in forum MediaReplies: 3Last Post: 30th Dec 2011, 07:48 -
BR structured image file is found as "unsupported"
By besthost in forum Authoring (Blu-ray)Replies: 4Last Post: 28th Jun 2009, 02:06 -
Installing programs to directory other than "default".
By Xylob the Destroyer in forum ComputerReplies: 5Last Post: 18th Aug 2008, 17:01 -
Just found this on [url]www.blankmedia.ca[/url]
By SilverBlade in forum MediaReplies: 0Last Post: 13th Sep 2007, 21:41
