What makes an SVCD compliant? All mine i make, Nero says that they are not compliant? Does it have to do with bitrate? or frames/sec ? or?
For SVCD you need an mpeg2 format file with certain specifications.
Read in the "What Is" section the part about SVCD's. You'll find it all there. -
There are a LOT of things required to make a MPEG-2 stream SVCD compliant -- more than just bitrate and framesize...
Unfortunately, not even the standard is completely clear and no encoder/muxer creates things exactly to spec. All you can achieve is varying levels on "non-compliance".
Regards.
Michael Tam
w: Morsels of Evidence -
there are strict standards for the svcd format however a player that does know how to play the svcd format will usualy work noncompliant svcd
if you do want the standards here they are :
resolution : 480x576/480(ntsc)
video bitrate : up to 2600kbps at vbr (you can get about 35
minutes of video at this bitrate )
if you work with bitrates lower than 1500 you will get results that are more or less vcd
audio sampling rate : 44100khz
audio bitrate : 32-384kbps
audio format : mpeg1 layer2 or mpeg2 multichannel (to be frank i haven`t seen ant standalone or even a software player that supports it)
that`s about it i hope i helped you -
Regards.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I think that pretty much sums it up. Non-compliant compliancy. I think I finally figured out this "context" thing.
WD TV is HDCP compliant?
By Supremo316 in forum Media Center PC / MediaCentersReplies: 1Last Post: 20th Nov 2009, 20:29 -
Wish to convert from .TS to compliant MPEG2
By gabier in forum Video ConversionReplies: 28Last Post: 9th Jul 2008, 04:34 -
making a compliant resolution mpeg2 file from a non-compliant .mkv file
By dwisniski in forum Video ConversionReplies: 1Last Post: 7th Mar 2008, 07:49 -
Anyway to make a non compliant disc compliant?
By zanos in forum Authoring (DVD)Replies: 9Last Post: 23rd Feb 2008, 11:46 -
HDMI compliant?
By vanjo in forum DVB / IPTVReplies: 6Last Post: 16th Oct 2007, 21:47
