i have a file...i think it's encoded with divx...well there's a little blip in the file that screws up the video for a second. while playing the divx file the sound matches up after the blip but when ripping the audio from the file it jumps the blip so in effect the sound file gets shortened and when laying it over while encoding the sound is a couple of seconds off after that...is there any way to fix this apart from cutting the file in two and removing the screwed part of the video?
You can edit the audio file and silence the blip, then remux to the original video.
Hello.
AVI2ISO sound problem
By Belfour in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2008, 14:37 -
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 19:37 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 04:51 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 07:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 21:22
