i have now backed up my dvd but it wont play on my home dvd player but it will play on my pc through media player
any suggestions ?
great site you people no your stuff
t. mclean
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Baldrick
Closed Thread
Maybe you should take the advice that the poster in the other thread you started gave you
https://www.videohelp.com/forum/viewtopic.php?t=211080
tricky trev
Member
Posted: Mar 12, 2004 13:32
i have used dvd shrink to shrink my dvd it then asked me to insert a blank disc it then made a perfect copy of the movie i thn tryed to play it on my home dvd player and it would not work i tried to play it on my pc and it played fine can anyone help with this problem
Report this post
louv68
Member
Posted: Mar 12, 2004 13:38
Click on the DVD Players box to the left of this webpage and see if the media you're using is compatible with your player.
Report this post
Tommyknocker
Flying Dutchman
Posted: Mar 12, 2004 13:46
It may be the burner program you used. If you use Nero, set the next DVD to be burned using UDF 1.02. It is a more backward-compatible format.
_________________
"You want to get Capone? This is how you get Capone: He pulls a knife, you pull a gun. He sends one of yours to the hospital, you send one of his to the morgue! That's the Chicago way, and that's how you get Capone!" -- The Untouchables
dvd player wont play AVI or dvd video burned discs
By rockerman in forum Authoring (DVD)Replies: 5Last Post: 20th Oct 2011, 14:01 -
Restore a DVD+R that wont play
By ProfHiggins in forum MediaReplies: 10Last Post: 14th Dec 2009, 23:49 -
LG DVB-T wont play DVD's
By scdom in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2008, 08:20 -
home made DVDs wont play on all stand alone DVD players. why?
By suomiaussie in forum Authoring (DVD)Replies: 12Last Post: 2nd Jan 2008, 21:59 -
DVD-R burned using a DVD Recorder wont play on any other player
By weaseal4 in forum DVD RippingReplies: 4Last Post: 22nd Oct 2007, 12:37
