  1. Do I really need to backup my files before using this software?
    What changes does it make to the original files?
    it's actually changing the audio from 41k to 48k on the original?
  2. just untick delete origanal mpg in the options.
    phil
  3. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    The demo changes the original files but the normal version doesn't. By default your mpgs will not be deleted or touched in anyway.... but as philmein says there is an option to delete these files.
  4. Thanks for clarification Chrissy.
    Maybe this difference should be more explicit in the upgrade page.
