I have a DV camcorder, a basic firewire card which captures only to AVI, and an ATI All in Wonder 128. I was wondering if it was possibel to capture to VCD MPG with this equipment from my camcorder.
If so which software could do this. If not what do I need to upgrade, or is it simply not possible to capture and compress to VCD on the fly from a DV camcorder.
Any info appreciated.
Firewire transfer from DV camcorder will only give you DV AVI. If you want to use your AIW to capture straight to MPEG (if your card allows, I'm not an AIW user), then you'll have to bypass firewire altogether, and use your camcorders analog out port. -
For capturing and compressing to VCD on the fly from a DV camcorde, you can use PowerVCRII 3.0 .
PowerVCRII 3.0 allows you to encode DV as an MPEG file directly, and in real-time.
Can you download 30-Day Free Trial version in:
http://www.gocyberlink.com/
I tried to use PowerVCRII 3.0 to capture DV straight to VCD already but the quality of the vcd file was not good at all.
My system is PII 800 with 512 Mb RAM, 40 Gb 7200 rpm HDD was used. Does anyone know what is minimum requirement for PowerVCRII 3.0 to work properly ?
Exsate DV Capture Live: AVI / WMV Capture Settings?
By Obtong in forum Newbie / General discussionsReplies: 1Last Post: 8th Jul 2011, 12:42 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31 -
Does simultaneous computer usage affect capture quality w/USB capture?
By miamicanes in forum Capturing and VCRReplies: 3Last Post: 19th Sep 2007, 19:05 -
Trying to capture Xbox 360 footage - Excellent Quality capture?
By Mysteriouskk in forum Capturing and VCRReplies: 5Last Post: 11th Jun 2007, 20:42
