i am trying to encode a avi film to mpeg but when i do there is no sound
what could be the problem lads.
Get a program called gspot and check the avi to see what kind of audio it is. If its ac3 audio tmpgenc wont encode it, you will have to split the audio from avi using virtualdub into a wav file and then encode the avi and the wav file together.
You might want to try to install the AC3 ACM Decompressor
Why?
Well here is the description of this usefull ummm utility I guess you would call it:
"Install this and you can convert/decompress AC3 audio directly to WAV/MP3 using Virtualdub. This also works with AVIsynth, TMPGEnc, allowing you to use AC3 encoded AVI files, not normally recognised."
Of course you will loose your original AC-3 audio since this will end up converting it to WAV or MP3/MP2 ... this might not be such a big deal if it is only 2.0 AC-3 but that would be a shame if it were 5.1 AC-3
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
