Some reason when I try to make a copy of a DVD copy I have I cant. Im using DVDXCOPY Plat ver 3.1?? Not sure of the Version since Im at work. My problem is that it will not pick up the DVD to burn. Now when I use a un burned DVD it will pick it up and im good to go. Was wondering if it might be a setting or something..Perhapse reinstall the DVDXCOPY PLAT?
Thanks in Advance
Results 1 to 14 of 14
Wouldn't a free tool like DVD Decrypter work for this? I haven't tried making a backup of a backup, doesn't seem logical since you should have the original. Unless of course its a copy of a friend's copy of a rental.
Just wondering if its possible ... The original is fubar and is not a option. I let a friend hold the DVD over the weekend and cracked it.
<edit> Replied before reading..... <edit>
But please search the forums this is undoubtedly discusesd weekly...
have a look at old threads...
Zworg2 -
Sorry but I did a search "copy DVD copy to DVD" and did not find anything. If you could put up a link of a thread dealing with this would be most helpful
I also looked @ the last 3 pages posted and found Zero Zip Nada
p.s.
All I want to know really is it DVDXCOPY that has a problem with copies of DVD to burn. If it yes then Ill do as the other member said and use DVD Decrypter
Thanks -
I've seen this problem before. I made a backup of a DVD with DVDXcopy, maybe the Gold version, I can't remember. It then wouldn't let me make a backup copy of the backup. For some reason it works now. Of course, I have also re-installed windows since then as well. Not sure if it's a bug or now. Try re-installing the program.
But like other's suggested, just rip the DVD with DVD Decryptor and burn the VIDEO_TS folder back to a DVD. That should get it for you. -
ThankS
Firgued be something I might be missing. Ill try to reinstall if that fails Ill try DVD Decrypter. -
And the same question comes to my mind:
WHY NOT MAKE A COPY OF THE ORIGINAL!!!!!!!!!!!!!!!!! -
Using Nero or RecordNow Max, just pop in the backup into the reader and the blank into burner. Click on copy and you are away. I know RecordNow will copy on the fly...pretty sure Nero will too. Once an original is backed up once, there is no more encryption.
Thats why =/ Dam Friends!
P.S.
Thanks I bet this is the problem. DVDXCOPY is looking for the encryption since there is no more enryption DVDXCOPY probably is stuck in a loop looking for it or something..
321 Studios, the author/owner of DVDXcopy and DVDXcopy Xpress is now being sued for supplying tools allowing you to copy encrypted DVDs. Their defense is:
You can not make a copy of the copy using their software.
Ths is how these tools were written!
Is that a good answer, Havek? -
DVD Decryptor is a better option in this situation anyway. ISO>Read ISO>Write. Minimum possibility for mess ups.
MB increases when making copy of video fie.
By MaddogX in forum Newbie / General discussionsReplies: 16Last Post: 12th Oct 2011, 13:15 -
How do i copy dvds onto hard drive and what is best software to copy sav
By bfishwick in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2009, 18:29 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
Making a copy with DVD santa
By 1234567 in forum Authoring (DVD)Replies: 2Last Post: 3rd Jul 2008, 03:19 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20
