Verbatim makes a disc that the front looks like a 8mm roll of film, very cool. It states 4x and not 1-4x. has anyone used this media on a pioneer dvr-104 with firmware upadte ver 1.4? will it work or possibably cause damage?
i have never used it. But also never seen it. Can you post a link to a picture of it?
this is the 2nd post i've seen about it and now i wanna see the damn thing.
Firmware upgrade 1.40 and above properly dealt with the overheating problem of burning 4X discs at 2X on the DVR-A04 (and DVR-104) burners. Go ahead and use them.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Supreme2k thanks for posting a pic. BestBuy had them for $9.99 for a 3 pack, and Samsclub.com had them for $35.97 for a 15 pack(I think you need a membership though)
SLK001- Thanks for the input I was probably going to try them anyway, just wanted to know if I understood the firmware update correctly. Thanks again.
Verbatim DVD-RW
By Jestak in forum DVD RippingReplies: 7Last Post: 11th Jun 2010, 10:27 -
verbatim DVD
By avextraxjp in forum Newbie / General discussionsReplies: 4Last Post: 7th Mar 2009, 20:08 -
Verbatim DVD+R DL Sale
By dutchdummy in forum MediaReplies: 2Last Post: 2nd Dec 2008, 17:02 -
Verbatim DVD+R DL Disks?
By albloom in forum MacReplies: 12Last Post: 21st Oct 2008, 09:52 -
Verbatim or Ridata DVD-R
By jyeh74 in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 01:57
