Page 4 of 4
FirstFirst ... 2 3 4
Results 91 to 108 of 108
  1. nope didnt work...humm??? it did work before on an early'r rls??
    not sure why this aint wotking... any ideas on the time of a newer verson??
    having2 use the old 1 .. (shame)?!!
    craig
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Ok. can you email me. We will be able to resolve this quicker.
  3. how can i make two titels? i have two movies but i can make only one titel. where i can edit the vts?
    i open the asset and put it 2 svcd files via drug&drop into titelset layout and want make seperate titels for each svcd file. only i see in menue window one titel, whats wrong?
    sorry for my english, i hope you can help me
  4. hehe, ok i found self, i must make a new vts over contextmenu in movie window, thx for help
  5. now i have another problem
    after encoding i only can see the movies on my pc, i burned the dvd and see it only over my dvd rom but i can`t see on my dvd player, whats wrong? my dvd player plays mad.
    only i can see the menu in my dvd homeplayer, but when i want starting a movie don`t passed
    further the cpu stress is extremly high
  6. Originally Posted by Slaky
    i have the same problem with the burned dvd.
  7. Originally Posted by donstc
    Same problem here. All versions after beta 1 have the same effect.
  8. not to be well the only one who have such problem
    i thought that i made a fatal mistake, it`s seems to be manufacturer still have a lot of work
    i think the encode button for movie titels don`t work correct, because all movie datas are physical on dvd, but not capable to invoice the right movie.
    the movie & titel conjunction are not conform
  9. Im having the same issue too.
    I have posted details in the "v2 Beta Released" topic
    Interestingly Slaky, I tried to create a DVD without menus and I still was unable to play the files so it may not be the menu to title conjunction that is in error, but actually something in the title files that mean they are not fully understood by some standalone players.
    I could be wrong, but I have tried using a skip title function on my standalone with DVDs created in v2 both with and without menus and although the display indicates the chapters and titles are being navigated, they don’t actually play.
    Hope this makes sense.
    - PS Chris where would you prefer the testing comments to be posted?
    PPS - Just wanted to reassure Chris that despite these teething problems, the interface looks good and the functionality and ease of use are beyond any commercial tools I have seen. Im sure that once these issues get sorted out, your tool will be truly genius.
  10. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Have a look at https://www.videohelp.com/forum/viewtopic.php?t=244555 and let me know if this is resolved.
    Thanks.
  11. anyone have make experiences with the latest beta 5 ?
    it's too good to last, so far i didn`t trust me to work with beta 5, because i have not enough dvds
  12. I need some help. I am running winxp with SP2. I have both versions of SVCD2DVD, 1.5 and beta v2 installed. They both HAVE worked in the past. Now that I put on the latest beta version BOTH stopped working. The installer also made me uninstall the last beta before it would install the new one. When I run 1.5 it I see the title screen, then nothing. When I run beta 2, it comes up with the registration screen and I have to put in the reg info over again. After I click the registration button nothing happens, just like the 1.5 version. Now I have NO usable version. What's up !!! TIA
  13. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    There may have been a change to your system. If you double click on the SVCD2DVD demo.exe file in the SVCD2DVD v1.5 folder you can redo the registration process. This should solve the problem. If not drop me an email.
    Regards,
    Chris
  14. Thanks Chris !!! Running the demo.exe did the trick. Both versions are now running again.
    Thanks Again
  15. Any where we can get the V2 with out donating 10 Bucks?
    Can someone post a link for the full version.
    TX
  16. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I assume you mean the demo.... Here it is: http://www.svcd2dvd.com/downloads.aspx#SVCD2DVD2
  17. This wont do anything over 2G. I thought this program would to larger files. Is there a way for you to fix that?
  18. Donate £10.....
    Not bothered by small problems...
    Spend a night alone with a mosquito
