do we have any exact date about the V2 yet? its been a couple of months and I hope the update is ongoing? Chrissy why dont you update us about the V2?
Results 61 to 90 of 108
No. It will be available when I have got it to a stable stage and testing has been completed.do we have any exact date about the V2 yet
It is but I have not being able to give it my full attention. If I could have, it would have been out ages ago. Both work & domestic comitements have ramped up in the last couple of months so my hobby - SVCD2DVD - has suffered.I hope the update is ongoing?
In software development terms, I estimate about 10 man days worth of effort remaining to get to a stage where v2 could go into public beta. It is just a case of my availability as to when I can fulfill this.
unicornz: Thanks for the post. My intention is to continue with improving what we have and not to go OTT.
Well currently there is:why dont you update us about the V2?
- new gui
- new code architecture. The core code has been completely rewritten & going forward, maintenence & new features will be easier.
- integrated demuxer. I have written one as when issue arise it is usually in this area. So when things choke I can fix them.
- ability to handle ac3 mpgs as inputs
- ability to handle mpgs with more than one audio stream.
- new menu builder with snap to grid & more alignment options than you can shake a stick at.
- Menu/DVD previewer (just menus at the moment but i might have it to preview the whole dvd structure using clips of the mpgs)
- audio menus.
- project saving/loading: this can facilitate templates
- Integrated burning (if you have Nero 6)
Thats just of the top of my head.
I have a few outstanding things I want in there b4 i stop & get all of that stable for the public. Once that has been tested I will release it (to keep everyone happy!). Then i will continue to add some more things i have on the todo list.
So v2 will probably be release in two stages. A preview so you guys can use it - & give feedback. Followed by a final release with more of the things that were promised.
The question is whether I can get stage one out b4 my holiday!SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Cant wait for new version Chris.... Your efforts will be appreciated by all i am sure.
1 question though. Will it be a free upgrade or a pay one...
Thanks -
All updates to SVCD2DVD are included with your registration.
Er.. yes. I was hoping that something could be released (either internally or externally) this week.... However I have had an XP SP2 nightmare which has lost me 2 days & I am still not recovered to where i need to be!!!
That said i am eager to get what i have out so that i can then get technical feedback. Thus if people want to beta test, email me with your typical svcd2dvd useage & I will choose about 10+ peeps to do an internal test with.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Originally Posted by ChrissyBoy
Good show m8, hi-use user (me) just e-mailed you
Well i have but still taking more. Include the videohelp nick in your email so i know that it is you!
BTW looking also for win98 & win2k users - all i have atm is winxp....SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
E-mail sent m8 also i can dual boot into win98 as well so i can also try that for you as well.. nps thereOriginally Posted by ChrissyBoy
The only thing I really wanted was an integrated ac3 encode (which seems to be going in... WOOT!). Other than that, the new interface looks GREAT! I can't wait for V2 to come out.
Will we be getting a feature that lets you convert straight from .AVI to the files for DVD burning
Thanks -
Often when I want to quickly watch a video on my TV (avi or what not), I simply encode it as an SVCD and let SVCD2DVD due the authoring. Since I am doing the encoding I actually encode the audio at 48kHz to avoid SVCD2DVD having to re-sample it. Problem is, the program demux's the file sees that it's already good, and muxs it back together anyway. It would be nice if the program would be intelligent enough to skip this step if the file already has 48kHz audio or at least be able check off a box to skip it. Unless it needs to be demux/muxed for some other part of the process it would be much faster to just add the nav packs and create the DVD folders.
Well it is my hope that registered users will be able to do so in the next day or so, but certainly by monday GMT!
im still getting errors with this new verson... the other one works fine
Type: System.ArgumentException
Source: mscorlib
Message: Empty path name is not legal.
InnerException:
StackTrace: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize)
at System.IO.StreamWriter.CreateFile(String path, Boolean append)
at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize)
at System.IO.StreamWriter..ctor(String path)
at SVCD2DVD.e679539bc4bbd8b5.e193f4af8ce48325(String e1f6a16d5ce3637b)
at SVCD2DVD.ddb8d1ea6c9958c7.8291881ef07bb5c7(Boolean 7ce1fdb24a74c398)
at SVCD2DVD.d3764d4f1e921081.4f3432523597dcf6(Boolean 7ce1fdb24a74c398)
at SVCD2DVD.d3764d4f1e921081.a727fa5530af9286()
at SVCD2DVD.d3764d4f1e921081.f81783e1b359ffc3()
help -
At what point does this happen?
Are you using custom audio?
then it comes up with the error at the end .. and the folder where the movie has been saved 2 isnt complete?
Can you re-download the beta to get the latest build?
Can you not use custom audio in the menu settings(use silence) and see if that gives you the same error.
As i can't replicate this can you email me the audio file for me to try?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
sorry my fault... NO im not using any audio in the menu...
but the settings are set 2 custom.... (would this cause the error) if im not using audio..and should i change it 2 silence???????????
regards
craig -
Yes. Please try that.
Discuss advanced ATSC broadcasting...
By edDV in forum DVB / IPTVReplies: 0Last Post: 22nd Oct 2011, 11:00 -
discuss ogg theora techniques
By zoobie in forum Video ConversionReplies: 11Last Post: 25th Aug 2008, 13:32
