The sequence in Premiere Pro is about 50 min and I selected NTSC DVD Progressive 4 mbps bitrate. The output file seems to have the right size (bitrate * secs). But when I play the output .m2v file in any player, the video is only 30 min. The audio lenght is right.
What am I doing wrong?
Thanks a lot!
I really don't know a lot about the output format you're using(progressive). I never use it. However, I did have this problem a while ago. I never used to multiplex either. For that file, I tried outputting a multiplexed DVD mpeg. It was fine(compared to the non-multiplexed m2v and wav files. Also, make sure you didn't do anything careless like have the timeline till only 30 mins when you were generating the video file. (I've done silly things like that before). Anyways, eliminate these cases before one of the gurus here can help you further. I don't know if it has anything to do with the progressive format you're using or not. Maybe someone else can help you with that.
Cheers.
Bt. -
The entire sequence is slected and output audio is full length. The output video appears to be full length (all scenes are there). It is just the time displayed on the media player is short.
I tried with interleaved as well and the same result. The only thing I didn't try is to multiplex the output. The default is output 2 separate files. -
Try opening the m2v in Virtualdub Mod. See if it reports correct length. Your media player could be giving incorrect duration.
Ther is no need to multiplex unless your DVD Authoring s/w demands it.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
Adobe Media Encoder
By kerb in forum Video ConversionReplies: 4Last Post: 27th Dec 2011, 20:15 -
crop and resize with adobe media encoder (at once)
By v1p0n3 in forum EditingReplies: 16Last Post: 9th Dec 2009, 15:25 -
Adobe Media Encoder CS4 resizing
By dedek74 in forum Video ConversionReplies: 4Last Post: 22nd Aug 2009, 14:37 -
Adobe Media Encoder MTS to Lagarith
By fitch.j in forum Video ConversionReplies: 8Last Post: 9th Jul 2009, 03:17 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 03:17
