I'm using iMovie4 and iDVD4.
I wanted to put something in along the lines of "extras" or "bonus materials". Something that wouldn't play off the main movie but rather you'd have to drill down to a submenu then click from one a few choices.
So far I've created a folder and dragged a short quicktime movie into it, but rather than showing as a submenu, it only play the movie in the background of a theme.
Anyone have any experience with doing something like this using iDVD4?
Double click the text of the folder you created. This will move you to a new menu, and you can drop the movie file as you so choose.
If it isn't broken, take it apart and find out why.
blog: deadsierra -
DS, thanks for the reply.
When you say "text of the floder", could you be more specific. When I created the floder, it populated it with a theme. I then dropped a quicktime movie in the well. the only "text of the folder" is the theme itself.
Also, how do you delete a folder once you've created it? -
Okay, so, when you click the new folder button, a bit of text should pop up that says "My Folder" or something like that, then, you can click the words once, and it should put a little selection box around it. Then you can hit delete to delete it, or you can double click it to open it up.
blog: deadsierra
software with submenus
By dipdog in forum Authoring (DVD)Replies: 5Last Post: 23rd Jan 2012, 00:28 -
highly customizable menus/submenus
By RBCC in forum Authoring (DVD)Replies: 20Last Post: 19th Jan 2012, 22:49 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43
