Does anyoen know how i can put a svcd header to a vcd file.
THe tmpgenc works but i wanna know how it works basicall. And where to put it in a vcd using a hex editor.
Have anyone tried to put SVCD header to a divx or xvid file and tested it to play on the standalone dvd player. Shouldnt it work theoretically since divx is hacked mpeg4 codec.
vcd is mpeg1
svcd is mpeg2
divx 3 is hacked mpeg4 ms codec
divx5+ is new mpeg4 codec
do a google search on hexeditors -- there are a 1000 of them.
good luck - since i'm not sure what you are trying to do .. would be a LOT of editing since headers are on every frame .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
By the way...DivX is not the hacked Microsoft MPEG4 codec you refer to. That was Divx 3.11 The Divx 4x & 5x versions (available for the past few years) were built from the ground up. You can read all about it at www.Divx.com
No, I'm from Iowa. I only work in outer space. -
Originally Posted by babybooOriginally Posted by BJ_M
Hi,
I suggest you try dvdpatcher from this website.
If you like, you could then compare a patched and an unpatched file with a hexeditor.
But be careful : the MPEG format with its streams and so on is NOT easy to understand (and patch). YOu could spend MANY hours in understanding where is what.
HTH
Tomgreetings
tom
Header stripping
By NikkiSix in forum Newbie / General discussionsReplies: 46Last Post: 17th Feb 2013, 17:57 -
Export Video Header
By BRotondi in forum Newbie / General discussionsReplies: 3Last Post: 18th Jan 2011, 15:35 -
covert avi header to mpeg header
By nidhi in forum Video ConversionReplies: 6Last Post: 29th Jul 2010, 19:40 -
How ican get the best picture quality of videos on lcd monitor via pc
By nusratjaveid in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2010, 06:49 -
Rewriting header
By DVDONE in forum Video ConversionReplies: 10Last Post: 17th May 2010, 15:11
