I don't know for sure if this is the right forum, or if there is a right forum for this, but WMP 9 stopped playing MPEG2 encoded videos. And somewhere along the way, Moonlight Elecard MPEG2 encoder took over the job, but now it says time is up and puts a dancing symbol on the video. I don't even recall downloading the Elecard, but I'm not the only one who has access to this pc. I may have d/l it thinking I was getting an encoder to use in video capture/edit/burning. If I uninstall the Elecard, WMP 9 will not play MPEG2 video, and it used to before the Elecard found it's way onto the pc. I've tried uninstalling/reinstalling WMP 9 with the same results. No MPEG2 playback. I suppose I need some drivers or something. So, how do I get WMP 9 to work properly without Elecard? Help...
WMP9 does not play MP2 on its own. It has to have a 3rd party codec. if it played it before you must have had a software DVD player like Power DVD or WinDVD installed. if so reinstall that program to get your codec back to operational. if you don't have one of those programs download the trial version of Power DVD, install and uninstall it. It'll leave its MP2 codec on your system, fully functional.
You might try this one, it's a freeware MPG2 codec.https://www.videohelp.com/tools?tool=323#comments
Windows Media Player dont play mpeg2
By mogoyon in forum Software PlayingReplies: 4Last Post: 14th Jan 2009, 14:31 -
MPEG2 file plays in windows media player but not properly in premier cs3
By ibanezfreak in forum EditingReplies: 1Last Post: 20th Oct 2008, 04:42 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
Windows Media player problem
By Super Warrior in forum ComputerReplies: 3Last Post: 17th Nov 2007, 14:20 -
problem with Windows Media Player
By marlo in forum Newbie / General discussionsReplies: 4Last Post: 17th Nov 2007, 10:52
