Hi,
I have tried several software tools to move a SVCD MPEG2 file to a DVD MPEG2 file. The original file can be played by MS MediaPlayer, but no scrolling is possible. After changing several paramters with TMPGEnc (like direct show filter etc.) and tried to use DVD2AVI as frameserver for TMPGEnc, but the tool ends anytime without error message during conversion (I try to convert to variable Bitrate).
Is there any tool available to check and maybe fix MPEG2 streams. I assume the original file to be not 100% correct as I am not able to scroll through the file with MediaPlayer, it can just be played and nothing more.
Do you have any idea, how I could handle that file ?
Thanks and regards,
Joe![]()
Hi,
I just want to push this upwards, maybe anyone reading only new posts might have on idea on my question.
Thanks,
Joe
Unsupported audio format in MKV file on LG 47LW5600 TV.
By kmplsv in forum Video ConversionReplies: 5Last Post: 23rd Feb 2012, 09:03 -
Unsupported format or damaged file -> ?
By ermetekos in forum EditingReplies: 1Last Post: 31st Mar 2010, 11:56 -
Unsupported FLV codec or format
By lovyagin in forum EditingReplies: 25Last Post: 11th Dec 2008, 23:13 -
Premiere 6.5 - unsupported compression format.
By vodmare in forum EditingReplies: 3Last Post: 28th Jan 2008, 16:51 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 17:51
