Guys,
Ever since i purchased SVCD2DVD I have not had one bit of luck trying to get my converted svcd's to play on my Pioneer DVD player. It wll play a SVCD fine from a normal cd, yet refused to play properly on DVD.
The problem i have is the screen is shown only half and pushed to the left hand side of the screen.Sound and picture is clear though, but its just skewed to the left hand side.
I have never had one conversion work successfully must have wasted around 30 blank dvds..
Please tell me the best way to do this. I would love to be able to see even just one work!
Results 1 to 9 of 9
Have you tried the Pan & Scan option?
Hi Chrissyboy.
Yes I have.. tried numerous things including that with no luck. Even tried enabling PAN and SCAN on the dvd player in the menu but no difference.. -
From the Svcd2DVD site
Have you got one of the 10% that doesn't work.NB: DVD-SVCDs work on around 90% of DVD players. To save both me & you some time try the Samples first if you have never played DVD-SVCD on your player before.
I suppose the other way would be to re-encode to DVD Mpeg2 .
If you have wasted a load of discs it might be a good idea to buy a DVD-RW disc to test on.
Good luck -
my advice would be to simply ditch that pioneer piece of rubbish and buy a cheap dvd player that plays everything as 99% of them do now and only cost around £40
Hi !
I have the same problem with Pioneer 535 model. It plays fine, it gives nice picture and sound but only with standard formats, no chance to use any patched or "masked" mpeg in producing VCD, SVCD, DVD. I use my Pioneer for standard compliance check.
Other DVD player Quadro 120 (paid 50 $) plays everything, even "dirty" DVB mpeg2 without reencoding and saving directly on DVD (or CD) without authoring. It recognises even opened RW CDs and DVDs without problems.
Regards
Tihomir
Anybody have any luck hacking TV/DVD combos?
By Martineaux in forum DVD & Blu-ray PlayersReplies: 2Last Post: 13th Mar 2012, 12:54 -
Pioneer 420k DVD player for canadians
By victoriabears in forum DVD & Blu-ray PlayersReplies: 47Last Post: 30th Aug 2011, 10:26 -
Cannot Make Back Up of Good Luck Chuck DVD
By MacPCConsultants in forum DVD RippingReplies: 11Last Post: 28th Jan 2008, 13:43 -
Philips vs Pioneer upscale DVD player, which one?
By hanugro in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th Dec 2007, 05:08 -
Qustion Dvd Player - Pioneer Dv393
By zaptos in forum DVD RippingReplies: 2Last Post: 28th Oct 2007, 09:26
