I have succesfully made lots of multis with this excellent proggy.
I have the latest version installed but recently I have had a few problems with lip sync in some films.
I have managed to fix the last 2 that were faulty.
After the BIN files have been extracted and -f applied with svcd2dvd the mpg is showing no errors in virtualdub but way off sync.
If I try to load mpeg into tmpgenc it will not load the sound.
I tried extracting the bin file with isoburn but got an error.
So I then used VCDGear v3.55 and told it to use
RAW Track image to mpeg
I then played the resulting mpeg in Virtualdub and its perfectly in sync.
Converted now with svcd2dvd and no lipsync in dvd
So why is vcdgear 1.76 in program not doing its job properly?
Thats twice now I have fixed lip sync problem this way without having to reauthor.
Before I tried this method I was reauthoring them in tmpgenc if they opened in it ok
Ok I have just extracted another set of bin files using the raw to mpeg in vcdgear and then converted and have no problems.
From now on I will extract my bin files like this b4 inserting the resultant mpegs into svcd2dvd.
Seems the only way I can guarantee success.
If vcdgear v1.76 extracts some of them their are lip sync errors in virtualdub but using this extraction method there are no lipsync errors in virtual dub
What you think chrissyboy? -
I think thats very interesting.
If I can replicate it I shall include this in SVCD2DVD.
Can you email me re getting a sample to test with?
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Unfortunately I have deleted the bin files now and the mpegs as I was struggling for space.
I might try and get 1st one again and get a sample for you.
However I can gurantee to anybody that the method I have mentioned above works all the time.
If this option can be included it will be amazing.
Will email you if I can retrieve bin file 1 again. -
ok sounds good.
drop me an email so i can get the settings right.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
email sent ChrissyBoy let me know if thats enough info.
Like I say after I extracted it that way your proggy converted it with no lip sync no problem
Gear For Church - Video Equipment
By krbowers in forum Newbie / General discussionsReplies: 2Last Post: 28th Sep 2011, 18:41 -
Start sector question in GEAR PRO
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 22nd Nov 2009, 15:23 -
No refunds on broken gear
By Noahtuck in forum Off topicReplies: 2Last Post: 28th Feb 2009, 08:53 -
Stolen Gear
By newsphotog in forum Off topicReplies: 7Last Post: 5th May 2008, 09:42 -
Gear Head DVD+R?
By bevills1 in forum MediaReplies: 1Last Post: 8th Jul 2007, 13:56
