I am capturing video as vcd mpeg for several hours and the files are sometimes about 2 GB, is there anyway i can spit mpeg files into smaller mpegs to fit on cds without having to render the file as it i will lose quality ?
Kinldy help me out
thank you
Even if I haven't tried it myself, there seems to be only one app that can cut mpg with something even approaching "problem free": Womble mpg vcr
I've tried every other app I could find to do this, but never got consistent success with any of them (major problem is sync issues).
/Mats -
I've cut mpegs with all sorts of tools, some work, some don't.
Regardless, I just run it through VCDGear, then burn.
Works every time.Cheers, Jim
My DVDLab Guides -
My thoughts exactly. Womble MPEG2 VCR is the best mpeg editor there is.Originally Posted by mats.hogberg
Just a suggestion, have you tried splitting it before converting, also if your using tmpeg enc. it has that nifty source range option.
I usually split before converting. I use easy video splitter which will allow you set a certain size, length, number of sections, or you can set slightly overlapping start points and end points and do as many as you like if there going to be on different discs, if there going to be on the same disc and your vcd player supports continuous play I would suggest not overlapping (it gives me a belly ache).
-=_Nexus_=-"We were in barstow on the edge of the desert when the drugs began to take hold." -
I agree, that's the ideal, but as forare is capturing directly to VCD spec mpg, teher's no conversion involved... The ideal in this case would be if it's possible to tell the capturing soft to split the output at certain size, like 780 - 790 MB.I usually split before converting
/Mats -
I was able to split the file using winproducer 3 , you can figure it to split the mpeg2 file at a certain size / time . Thanks for all the help
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 19:16 -
SPLIT A LARGE VOB FILE INTO 1GB CHUNKS AND AUTHOR
By jimmalenko in forum User guidesReplies: 39Last Post: 12th Aug 2011, 09:37 -
Vdub script / tool etc - split large file into 10 min segments? (auto)
By Jynks in forum Newbie / General discussionsReplies: 0Last Post: 17th Apr 2010, 06:19 -
Large MKV split on two DVDs
By bjb39 in forum MacReplies: 2Last Post: 1st Dec 2009, 21:01 -
large file split for multiple displays and convert ... what tool 2 use?
By rodpacker1 in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 03:03
