    Mar 2003
    Tacoma,WA
    I have a Hauppage TV tuner card and I am trying to capture a 1 hr tv show with Microsoft Movie Maker.
    I can get the MM to see the card both video and sound the problem is Once I enable MM it saw the first sation the Hauppage card was on and now I cant get it to change channels.
    I go to "New Projects" and it still sees the same channel it origanaly saw.
    I have also changed the channel in the WinTV 2000 Hauppage program and the MM still goes back to the same channel.
    Can anyone help me figure oout how to change channels in Windows MM?
  2. in WMM2, select device > configure > tuner . select channel.
    Always check helpfiles/instructions before leaping...
