Hi,
would like to try a tbc but cant find any vcrs with it or a tbc box in New Zealand which is pal and have asked a few shops if they can get a vcr with tbc but they have no idea what tbc is let alone get any vcrs with it.
so my question is TBC for NTSC only and pal doesnt require tbc for correction?
TurboRunner
You can get TBCs for PAL systems.
I don't know about integrated TBCs in VCRs, but DataVideo makes the TBC1000P. It's the the same thing I use except it's for PAL instead of NTSC. It runs about US$ 350.00.
www.bhphotovideo.com is where I'm quoting from...
Confused: Why a VCR with TBC if separate TBC needed anyway?
By tluxon in forum RestorationReplies: 211Last Post: 2nd Aug 2013, 19:31 -
New to tbc - need advice on optimizing Panasonic svhs ag1970 w/tbc
By yoda313 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2011, 09:43 -
TBC suggestions: TBC-1000, AVT-8710, ADVC-300, TV1-TBC, or TV1-TBC-GL
By m27315 in forum RestorationReplies: 16Last Post: 24th Mar 2010, 01:36 -
TBC's, TBC's, TBC's, upto my knees ........ puzzling over sync controls?
By StuR in forum RestorationReplies: 6Last Post: 22nd Nov 2007, 11:58 -
panasonic VCR tbc + external tbc - any use ?
By abbymat in forum RestorationReplies: 13Last Post: 15th Aug 2007, 08:29
