ok, ive posted about this several times and no one seems to know what this is, i encoded an mpeg using Tmpegnc to lower the KBPS, cause it was too high.......now thats ok at 1150 but the system clock ref is too high at 1084, HOW DO I LOWER IT so i can burn it as a vcd
Demultiplex your mpeg and remultiplex with any VCD aware muxer (e.g., TMPGEnc or bbMPEG). If you use TMPGEnc, make sure you put it on the setting "MPEG-1 Video-CD".
Regards.
Michael Tam
w: Morsels of Evidence
Possible to change ref frame value w/out recoding?
By dave in or in forum Video ConversionReplies: 4Last Post: 2nd Aug 2011, 21:11 -
MultiAVCHD - Ref frames
By bobo343 in forum Authoring (Blu-ray)Replies: 0Last Post: 10th Feb 2010, 11:25 -
Reducing Ref-Frames in x264 videos
By hulked in forum Video ConversionReplies: 0Last Post: 7th Jan 2009, 11:10 -
PS3 AVCHD, Ref Frame 8+Level 5.1+B-Pyramid...????
By NiGHTsC in forum Video ConversionReplies: 1Last Post: 29th Dec 2008, 19:45 -
Ref Creatix SAA7131, Triple Capture Device
By lmortiss in forum Capturing and VCRReplies: 0Last Post: 14th Apr 2008, 11:16
