Can anyone tell me how to find out why I'm dropping frames. I used to capture without dropping, but now I drop 200 to 500 in a 30 minute DV. I've defragged,run enditall,etc. I watch task manager while capturing and and Studio CPU useage is around 5% and the balance of CPU is in system idle process. Thanks for any help. Foz
Foz the newbie
Hmm... Hard to say... Did you check DMA setup ? Did anything changed with PC ? New hardware, new driver, new BIOS ? Is camcorder getting older ? Trouble with cable ??? Just shooting around... Did you check PInnacles Webboard ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
donpedro, Answers to your questions:
Did you check DMA setup,both HDD running UDMA mode 5
New hardware, new NEC 1300A DVD burner
new driver, D/L Intel Application Accelerator drivers, trying to correct dropping
new BIOS ? same Bios
Is camcorder getting old, about 6 months old
1394 cable almost new, I have posted on Pinnacle board and a lot of other places. Just don't have the know how to correct problem. I definitely know more now than when I made my 1st capture and had no problems with this frame dropping issue. Just watching task manager with Studio 8 running capture, around 5 CPU useage and system idle showing the balance of CPU, for apparently no reason capture may drop 5 to 25 frames and then smooth running for a minute or 2 or 3 and then drops again. Thanks for your Interest FozFoz the newbie -
Again... I am just shooting crazy ideas, but what about unpluging DVD Writer ?
Finally got my frame dropping cured. I had 359 files in my IE
favorites, I copied this favorite folder to 2nd HDD, and deleted the
favorites in IE down to 63 files. I captured two 30 minute DV tapes without
dropping a frame. Thanks to all. FozjFoz the newbie
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 12:36 -
Analog capture with Studio Pinnacle 15HD, Dropped frames?
By rivrbyte in forum Capturing and VCRReplies: 2Last Post: 31st Dec 2011, 16:00 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
HDVSplit dropping frames
By Boadicea7 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2009, 09:47 -
Pinnacle Studio+ 10.7 interlaces my video after 250 frames ?
By blewyn in forum EditingReplies: 1Last Post: 8th Jun 2008, 23:56
