Hi everyone. I need help trying to make a dvd.
I have the video in avi which i extract the audio and video. The video i encoded to dvd compliant mpg and the audio i got in ac3 format. Now i cant seem to add the ac3 audio to my video using ulead movie factory 2 or sonic mydvd le version 5. They both accepted mp3 but i ended up with an uncompatible dvd.
If the MPEG file is DVD-compliant, demux it. Open IfoEdit, select DVD Author--Author New DVD.
Load the .m2v file as video, and the AC3 file as audio, add your .sup file if you are adding subtitles, name the target directory, select OK.
The resultant files can be burned with Nero, or whatever your favorite DVD burner program is.Hello. -
Do you have an MPEG file (aka filename.mpg) or a M2V file (aka filename.m2v)Originally Posted by arrel007
If you have an MPEG file you need to demultiplex it. This can be done with a variety of programs including TMPGEnc (FILE ---> MPEG TOOLS)
Once you get a M2V file you can then use TMPGEnc to multiplex the M2V and AC-3 into a single MPEG (aka filename.mpg) file.
You should now be able to use this with MF2 ... not sure about SONIC MYDVD but my guess is it will work with that as well.
FFMPEG adding audio to mpg video => QT bug
By Tom2me in forum MacReplies: 3Last Post: 6th Aug 2011, 06:27 -
Adding AC3 audio to MKV video
By switch_foot4 in forum Newbie / General discussionsReplies: 2Last Post: 26th Oct 2009, 01:35 -
adding captions to cablelabs spec mpg
By christianolovesvideo in forum SubtitleReplies: 0Last Post: 28th Sep 2009, 18:38 -
Adding audio to end scene of mpg video
By martin01p in forum EditingReplies: 5Last Post: 10th Oct 2008, 07:04 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48
