Hi,
For some reason my dvd writer stopped working... something along those lines. I have SONIC software installed that came with it and I downloaded Nero 6 demo as I usually do (when needed) to burn DVDs and such. But for some reason my burner won't burn. Nero rejects the discs or continues to eject the disc. I've tried a few different brands and none of them work. I'm guessing that it was definitely something I did. Does this sound familiar to any one? Any experience soemthing like this? The writer doesn't recognize discs in general. It's worked perfectly before, up until recently. I just can't figure what I may have done exactly to change every thing. Not sure what specifics to share, DVD+Rs and what I'm burning is basically what I've made with my Philips standalone recorder- I used dvddecrypter to rip to my pc and I add chapters and burn with Nero. Those are the basic programs. Again worked perfectly before. OH I usually use dvdderypter with my CD/DVD Rom drive and then of course burn with my second DVD drive both internal..... Kind of upsetting, any response (email or otherwise) is welcome.
Thanks,
Mary (smeagollum@sbcglobal.net)
Results 1 to 10 of 10
If possible email directly with replies.
Best to try the burner in another computer and if it still has problems then the burner wernt belly up,if it works ok in another system then something in the o/s got corrupted such as the imapi.
I had Nero installed on my pc when I bought my DVDRW drive. I fitted the DVDRW drive in place of the CDRW that I had been using and everything worked perfectly. I then decided to try the Sonic MyDVD software that had come with the DVDRW. After installing that, I found that it didn't work and neither did Nero anymore. Uninstalling either and everything worked again. Sounds like you have a similar problem which probably depends on the exact configuration of your pc. I simply didn't bother with the Sonic software anymore as it also screwed up my Ulead Mediastudio Pro installation.
Hey folks,
I tried everything ya'll suggested- accept for a clean RE/install. I was hoping that I didn't have to. Here's the thing, I removed Sonic Software and Nero Software and just installed the Nero Software but the burner still isn't working. It's sort of like stuck because it dies after it spins for a couple seconds.
OKAY so ... I have around 3 GBs of info, I want to save somewhere, and of course I would have made a backup if I had known that my burner was just going to stop, anyone have any tips on how to save "my stuff" before doing a full format? Suckage... wonder what I did.
Thank you very much for the suggestions btw.
Thanks,
MareIf possible email directly with replies. -
Ok I saved my stuff and managed to do a format of the OS reset to factory settings etc... and installed chipset as instructed for my 4100 dell. (win98) Still hv eth esame problem. I have a PCI device driver missing. Anyone know what driver is apprapo for this? Also... anyone know what's the matter? (aside from the drive being dead) I really hope not. I want to exhuast all the possibilities before accepting that conclusion please.
Anyway... all possible suggestions accepted and most welcome.
DVD/RW is Lite-on LSW 401S
CD/RW-DVD+rom is GCC-5120B
Win98se
Not sure what more info to add. Just ask.
Thanks!
- Mary
smeagollum@sbcglobal.netIf possible email directly with replies. -
Have you tried using a CD laser lens cleaner on it?
Capmaster,
No, should I? I have one.
Thanks,
Mary
[edit] I mean one of those disc cleaners with the mini brush on it right? Not a liquid solution or anything.If possible email directly with replies. -
FAAAA-REAKKKYYY
I used the Lens Cleaner and I just burned a perfectly "healthy" DVD+R
I was doing everything but think that I should clean it. My room must be dirty. ;p
THANK YOU So MUCH CAPMASTER
As with every one who suggested and helped.
Damn this probably meant that I didn't need to do a format of the OS. Hahah oh well.
Sincerely,
MaryIf possible email directly with replies. -
NPOriginally Posted by Rhysfire
Glad it's working. Remember ...always try the easy/simple/free solutions first. Then start turning over rocks
With the volume of DVDs I burn (20 - 30/week) I have to clean mine about once every 2 weeks. Being dusty here makes it worse. I know it's time to clean when Nero fails the power calibration it does just as it's starting the burn. I use one of those Scotch cleaning discs with the little brushes like you mentioned.
Look on the bright side - reformatting and reinstalling the OS makes it screaming fast again ...until the registry and fonts folder fill up again, that is
Error Reading by GOM and Media Player Classic in reading MKV video
By cutefix in forum Software PlayingReplies: 1Last Post: 31st Mar 2009, 00:25 -
Writer not burning at 16x like it should
By championjosh in forum DVD & Blu-ray WritersReplies: 7Last Post: 4th Mar 2008, 02:59 -
DVD Writer suddenly not reading DVD's... why?
By Vanna in forum DVD & Blu-ray WritersReplies: 7Last Post: 27th Feb 2008, 21:29 -
Writer burning discs erratically
By uNderdog_101 in forum DVD & Blu-ray WritersReplies: 11Last Post: 28th Nov 2007, 14:08 -
Problem with burning using my LG writer won't go away
By pwil30 in forum DVD & Blu-ray WritersReplies: 7Last Post: 16th Jul 2007, 10:12
