I'm losing audio sync sometimes when I'm triming the beginning and ending parts of a video with Ulead VideoStudio 6.
I'm backing up my VHS tape collection to DVD and here's what I'm doing.
1) VHS ==> Sony TRV320 DV Camera via A/V ==> PC Via Firewire. (I bought an vcr for "my computer" specifically for this. Macrovision is not a problem (so far), I'm able to backup Disney and other VHS tapes this way. Even tapes (e.g., Disney) that the Sony WOULD NOT let me record to DV tape ... this method will allow me to capture them to my harddrive by passing them through by DV camera without a DV tape inserted).
2) Because I don't want to baby sit this process I generally have a few seconds at the front of the capture and several minutes at the end of the capture that I'd like to edit out. I'm using VideoStudio 6, which I purchased off of ebay for $20, for capturing. I'm getting AVI files ranging from 20 to 30 GB (90 to 130 minutes) in size. At this point the audio and video are still in sync at (or near) the end of the movie.
3) I then use Ulead VideoStudio 6 to trim the "clip" (large avi file) and then save that timmed file. The save is treated as a render but is fast (I guess) (30-minutes of so). I've done this two times. The first time the audio and video remained in sync. The second time (or movie) I lost sync. By the way, I've tired using VirtualDub for the trimming but VirtualDub is unable to get the audio stream.
4) One workaround, I've thought of, is to recapture the movie so that I don't have to trim out any video. However, I'd like to be able to trim and not have to go through the recapturing and baby stitting the capture to ensure that the video starts and ends at the correct places.
Any thoughts or suggestions are appreciated.
Since Virtual Dub cannot capture the audio stream, try using the Virtual Dub AC3 version.
Hello. -
Use VirtualDubMod to edit your DV AVI file. When you are done doing the trimming go to TOOLS then SCRIPT EDITOR
Now the VirtualDubMod Script Editor window pops up. Click on EDIT then IMPORT FRAMESET AS TRIMS
Now copy and paste this into an AviSynth AVS script.
The script doesn't need to be fancy. Just something simple. As an example:
Code:AviSource("D:\capture.avi") Trim(717,11507)
However ... the nice thing about using AviSynth is that not only do you not have to re-save or re-render your original capture (a big plus) but you can also filters to help improve the video quality.
One such filter that works great with DV AVI captures is the ReInterpolate411 filter
Here is a link to thia AviSynth 411 filter:
http://www.trbarry.com/ReInterpolate411.zip
I think you will have to right click on this and then select SAVE TARGET AS ... to get this link to work.
Basically this filter helps with the conversion from DV AVI (which uses a 4:1:1 colorspace) to the MPEG-2 DVD format which uses 4:2:0
Help: losing audio on TV going from HD to SD content
By scarecroe in forum DVB / IPTVReplies: 2Last Post: 26th May 2010, 15:29 -
losing audio help
By tim37 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2009, 21:45 -
Add audio track without losing menu?
By levon in forum Authoring (DVD)Replies: 3Last Post: 1st Feb 2008, 04:26 -
Audio problems with Ulead VideoStudio 8
By beanosirra in forum Newbie / General discussionsReplies: 4Last Post: 14th Jun 2007, 09:35 -
Exporting audio from VideoStudio 9. Possible?
By markannab in forum AudioReplies: 2Last Post: 6th Jun 2007, 20:48
