Hi Chris
I've read forums, updated Cygwin.dll (ver 1.005.7), ran Mpeg fix on all mpg files and still stopping on multiplexing. The scrolling bar at the bottom of window dissappears and every thing stopps.
My Log
Starting SVCD2DVD: v1.51.2.0
Begin time: 6:39:59 AM
******** Ripping BIN images to get mpegs (VCDGear )
Analysing File: G:\2nd hand lions2_FIXED.mpg
++ WARN: packet length beyond buffer (pos = 20 + size = 2028 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
Analysing File: G:\2nd hand lions_FIXED.mpg
!ASSERT: file vcd_mpeg.c: line 506 (_analyze_pes_header): assertion failed: (vcd_bitvec_peek_bits (buf, pos2, 8) == 0x0f)
2 [sig] vcdxminfo 2664 open_stackdumpfile: Dumping stack trace to vcdxminfo.exe.stackdump
Error getting mpeg details. (probably due to AC-3 audio)
System.IO.FileNotFoundException: Could not find file "G:\2nd hand lions_FIXED_info.xml".
File name: "G:\2nd hand lions_FIXED_info.xml"
at System.IO.__Error.WinIOError(Int32 errorCode, String str)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials)
at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
at System.Xml.XmlTextReader.CreateScanner()
at System.Xml.XmlTextReader.Init()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlValidatingReader.ReadWithCollectText Token()
at System.Xml.XmlValidatingReader.Read()
at System.Xml.XmlLoader.Load(XmlDocument doc, XmlReader reader, Boolean preserveWhitespace)
at System.Xml.XmlDocument.Load(XmlReader reader)
at System.Xml.XmlDocument.Load(String filename)
at _S_VCD2DVDMPG.210ff09a2516b1a7.b4e369192c57af39(2b c216f3ce925842 a01d771a37e7320b)
Analysing File: G:\gotica1_FIXED.mpg
++ WARN: mpeg stream contained no scan information (user) data
Analysing File: G:\gotica2_FIXED.mpg
Analysing File: G:\gotica3_FIXED.mpg
Analysing File: G:\passion1_FIXED.mpg
1 [sig] vcdxminfo 2432 open_stackdumpfile: Dumping stack trace to vcdxminfo.exe.stackdump
System.IO.FileNotFoundException: Could not find file "G:\passion1_FIXED_info.xml".
File name: "G:\passion1_FIXED_info.xml"
Analysing File: G:\passion2_FIXED.mpg
-->Processing 7 mpeg files.
############### New MPEG File ###############
Type: SVCD
Horizontal Res: 480
Standard: NTSC
Audio SampleRate: 48000
******** Demultipexing original mpg file
(Total size: 662MB, Duration: 00:00:59, Rate(MB/Min): 673.04)
******** Resampling audio from 44.1 KHz to 48 KHz
Skipping....
******** Multipexing elementry streams
INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
**ERROR: [???] File G:\2nd hand lions2_FIXED_DVD.mpv unrecogniseable!
**ERROR: [???] File G:\2nd hand lions2_FIXED_DVD.mpa unrecogniseable!
**ERROR: [???] Unrecogniseable file(s)... exiting.
System.IO.FileNotFoundException: Could not find file "G:\2nd hand lions2_FIXED_DVD.mpg".
File name: "G:\2nd hand lions2_FIXED_DVD.mpg"
at System.IO.FileInfo.get_Length()
at _S_VCD2DVDMPG.210ff09a2516b1a7.6b5e366e276d88bf(2b c216f3ce925842 a01d771a37e7320b)
at _S_VCD2DVDMPG.210ff09a2516b1a7.f5d131c1b9f0edc5()
Don't understand what log means
Thanks for help
Garegina
G:\passion1_FIXED.mpg & G:\2nd hand lions_FIXED.mpg can't be processed.
If you have the original bins i would try VCDxRip as the ripper & see if that makes a difference.
Failing that I will take a look at a sample.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Burned Divx movies stopping before end...
By Jeffross1968 in forum DVD RippingReplies: 9Last Post: 18th Feb 2012, 12:08 -
Video Keeps Stopping On My Site
By Frustrated1 in forum MacReplies: 16Last Post: 5th Apr 2010, 01:59 -
Play divx files without stopping
By occasional in forum DVD & Blu-ray PlayersReplies: 4Last Post: 14th Feb 2009, 08:20 -
TMPGEnc DVD Author 3 - Stopping it Re-encoding
By Incast in forum Authoring (DVD)Replies: 12Last Post: 8th Aug 2007, 18:45 -
Capturing and stopping via command line
By diamond187 in forum Capturing and VCRReplies: 1Last Post: 11th Jul 2007, 17:03
