Results 1 to 10 of 10
  1. Hey guys. Not exactly sure if this is the right forum for it, but here goes...
    I downloaded a file off the net that was made of 4 .bin files (around 800MB) and .cue files (1kb). I was just wondering how to change these files to be able to play on a DVD player. Any help?
    Oct 2003
    deep in Wonderland.
    Originally Posted by Dr. Rick Dagless MD
    Any help?
    Yes.
    Fight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
  3. Thanks guys, but it won't let me burn it onto a DVD, it just wants a CD-RW. Should it do this?
    Oh, and sorry for posting the topic int eh wrong place.
    Nov 2003
    sunny old london
    download Iso buster and extract the MPeg files, shove them in TMPEGnc, and convert them to a dvd compliant file, guides on how to do this are on the left
  5. Member steptoe's Avatar
    For .bin/.cue files I've always used CDRWin, as its done the job first time everytime, and I've done hundreds of these types of images, over a couple of years
    These are normally disk images, so that could be why its asking for a CD/CD-RW
    I've tried Nero, but could never get it to work properly with these files, so went back to CDRWin....
    Always use what you know works perfectly for you
  6. CDWIN won't work with DVDs either. Is it just a thing that .bin or .cue files will not work with DVD-RW?
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    I missed the subject(bin to dvd). You must convert it to dvd-video as lostbee says. If it is vcd or svcd you can use www.svcd2dvd.com and do it in one step.
  8. I have an img file which I've used isobuster to extract a bin file. It has only extracted a bin file however, and not a cue file. I tried to extract the mpg from it, but it cam up as 0bytes and corrupted, i'm not sure if i should have done this?
    I tried to extract a raw file from the bin file, but i'm not too sure wht to do with that either.
    Can anyone pls help.
    Bev
    -x-
  9. Alcohol 120% & Nero are excellent BIN burning programs. You don't even need the CUE files with these two.
    Boda
