When using Nero i start to burn and everything is ok,the estimated time usually about 13 minutes BUT it takes longer than 13 minute,20 -25 minutes to be exact.
Anybody got any idea's?
I have tried 3 different types of media so far.
Any idea's on the best media to use and wher to get hold of it ????
Use DVD Identifier or DVDInfoPro to find out the media code of the discs you are using, since they will indicate the acceptable burning speed. It sounds like those discs are burning around 2.4X. Also, you can also transform your OEM U14A to a retail DRU-510A, since firmware support is better for a retail drive. If you want to convert, check here, since I was able to convert a friend's older U12A to a 500AX. You can also edit the registry to let Nero show the actual burning speed by looking at here.
Smart render in Sony Vegas 11 for Sony Bloggie MHS-FS3 mp4 files
By ekendahl in forum EditingReplies: 8Last Post: 27th Aug 2011, 19:41 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Wedding Videography Sony HDC 900 or Sony PMW EX3 ? Tapes?
By mek in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Oct 2010, 14:35 -
Sony TVR-460 with FireWire cable 4pin undetected by Sony Vaio Laptop
By vatsyk in forum Capturing and VCRReplies: 4Last Post: 11th Dec 2009, 18:45 -
Importing from SONY HDR-SR1 to SONY VEGAS 8 MPEG Video resolution
By UltimateEnd in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 19th Oct 2009, 12:00
