I have an mpg file that conforms to vcd except it is too large to fit
on a 650MB CD. Actually I have six of these. Can I put them on one DVD? If so how?
look at the guides on the left on how to convert a vcd mpg to a dvd
JustSomeGuy, note that VCD does away with the error correction overhead that is used on ISO data CDs. That means an 800 meg VCD compliant MPEG file will fit on a 700 meg CD-R if you burn it as a VCD, maybe even a 650 meg CD-R.
Yes you can . I use TMPGenc DVD Author for that job . You can get around 7 hours of mpg1 onto a dvd-r . The only thing wrong with the vcd-mpg is the audio will be at 44.1KHz but TMPGenc DVD Author will convert that to 48KHz for you which will make it DVD compliant . Then burn to a dvd-r .
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
Can't convert very big file
By Julio33 in forum MacReplies: 3Last Post: 16th Dec 2010, 15:18 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 18:52
