I am preparing files to be burned onto a 4.7gb dvdr disk. The encoding fails. This is what I get:
My elemental streams are well under 4.7 gb. Why does it want to split it?Code:INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames Wed Mar 10 15:31:38 PST 2004 INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr> INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes) INFO: [yuvscaler] input: frame rate: 30000/1001 fps (~29.970030) INFO: [yuvscaler] input: interlace: none/progressive INFO: [yuvscaler] input: sample aspect ratio: 1:1 INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE INFO: [yuvscaler] scale to 720x480, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm, INFO: [yuvscaler] without line switching INFO: [yuvscaler] without time forwarding INFO: [yuvscaler] Without luminance correction INFO: [yuvscaler] Without chrominance correction INFO: [yuvscaler] frame rate: 29.970 fps INFO: [yuvscaler] Scaling ratio for width is 1 to 1 INFO: [yuvscaler] and is 1 to 1 for height INFO: [yuvscaler] Specific downscaling routing number 4 INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes) INFO: [yuvscaler] output: frame rate: 30000/1001 fps (~29.970030) INFO: [yuvscaler] output: interlace: none/progressive INFO: [yuvscaler] output: sample aspect ratio: 1:1 INFO: [mpeg2enc] Selecting DVD output profile INFO: [mpeg2enc] Assuming norm NTSC INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/carey/Movies/SantaClause2/output/SC2.m2v INFO: [mpeg2enc] Horizontal size: 720 pel INFO: [mpeg2enc] Vertical size: 480 pel INFO: [mpeg2enc] Aspect ratio code: 2 = 4:3 display INFO: [mpeg2enc] Frame rate code: 4 = 30000.0/1001.0 (NTSC VIDEO) INFO: [mpeg2enc] Bitrate: 5300 KBit/s INFO: [mpeg2enc] Quality factor: 3 (Quantisation = 3) (1=best, 31=worst) INFO: [mpeg2enc] Field order for input: none/progressive INFO: [mpeg2enc] New Sequence every 9999 Mbytes INFO: [mpeg2enc] Assuming non-video stream of 246 Kbps INFO: [mpeg2enc] Search radius: 16 INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15 INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC" INFO: [mpeg2enc] Progressive format frames = 1 INFO: [mpeg2enc] Using default unmodified quantization matrices INFO: [mpeg2enc] Buffering 39 frames INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER! INFO: [mpeg2enc] SETTING AltiVec for MOTION! INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM! INFO: [mpeg2enc] SETTING AltiVec for PREDICTION! INFO: [yuvscaler] End of stream! INFO: [yuvscaler] Normal exit: end of stream with frame number 187637! INFO: [mpeg2enc] Guesstimated final muxed size = 4226364032 INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16 INFO: format = 0x1, audio length = 1202078856 bytes INFO: slots/frame = 672 INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz INFO: System is big endian INFO: Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps INFO: Encoding with psychoacoustic model 2 is finished INFO: The MPEG encoded output file name is "/Users/carey/Movies/SantaClause2/output/SC2.mp2" INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $) INFO: [mplex] File /Users/carey/Movies/SantaClause2/output/SC2.m2v looks like an MPEG Video stream. INFO: [mplex] File /Users/carey/Movies/SantaClause2/output/SC2.mp2 looks like an MPEG Audio stream. INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options! INFO: [mplex] Found 1 audio streams and 1 video streams INFO: [mplex] Selecting dvdauthor DVD output profile INFO: [mplex] Multiplexing video program stream! INFO: [mplex] Scanning for header info: Video stream e0 (/Users/carey/Movies/SantaClause2/output/SC2.m2v) INFO: [mplex] VIDEO STREAM: e0 INFO: [mplex] Frame width : 720 INFO: [mplex] Frame height : 480 INFO: [mplex] Aspect ratio : 4:3 display INFO: [mplex] Picture rate : 29.970 frames/sec INFO: [mplex] Bit rate : 5300000 bits/sec INFO: [mplex] Vbv buffer size : 229376 bytes INFO: [mplex] CSPF : 0 INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/carey/Movies/SantaClause2/output/SC2.mp2) INFO: [mplex] MPEG AUDIO STREAM: c0 INFO: [mplex] Audio version : 1.0 INFO: [mplex] Layer : 2 INFO: [mplex] CRC checksums : no INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec) INFO: [mplex] Frequency : 48000 Hz INFO: [mplex] Mode : 0 stereo INFO: [mplex] Mode extension : 0 INFO: [mplex] Copyright bit : 0 no copyright INFO: [mplex] Original/Copy : 0 copy INFO: [mplex] Emphasis : 0 none INFO: [mplex] SYSTEMS/PROGRAM stream: INFO: [mplex] rough-guess multiplexed stream data rate : 5613544 INFO: [mplex] target data-rate specified : 10080000 INFO: [mplex] Setting specified specified data rate: 10080000 INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16022 INFO: [mplex] New sequence commences... INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000 INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000 ++ WARN: [mplex] File size exceeded before split-point in video stream INFO: [mplex] Starting new output file... **ERROR: [mplex] Need to split output but there appears to be no %d in the filename pattern /Users/zerko/Movies/SantaClause2/output/SC2.mpg
-B.
https://www.videohelp.com/forum/viewtopic.php?t=195815
Version 0.0.9b will correct this bug and it's due for release within some days.
Properly preparing a VOB with pulldown for Vegas Pro 10.
By rcavanah in forum EditingReplies: 10Last Post: 14th Sep 2011, 17:51 -
preparing video clip for editing in adobe premiere and burning to a dvd
By namreeb808 in forum Newbie / General discussionsReplies: 3Last Post: 18th Feb 2011, 00:13 -
Preparing Video on a PC for editing on a Mac with iMovie ?
By beammeup in forum MacReplies: 5Last Post: 13th May 2009, 20:57 -
Preparing Video for YouTube
By markannab in forum Video ConversionReplies: 121Last Post: 28th Aug 2008, 20:47 -
Preparing for preview with avisynth
By themaster1 in forum Video ConversionReplies: 0Last Post: 28th Oct 2007, 19:54
