    Jan 2004
    NearBrussels Thats Europe
    I've had some good results using TMPEGnc but I have a few movies where the audio sync goes out of line. They play fine as AVI's. Often the audio is ahead of the video.
    How do i get audio and video back in sync?
    cheers
  2. I have the same problem but mine is when I use Studio 9 and it dose not do it every time. any ideas ,thanks[/img]
    Jan 2004
    Thanks RXH102, that was helpful. I found that of profound interest.
    Don't hi jack, write your own post.
    did you try convert the audio to wav/pcm? and used it as audio source in tmpgenc?
    www.dvdrhelp.com/tmpgenc#problems
    Dec 2003
    Pinnacle was doing that for me - i think it does it when it re-renders ?? i juse capture in P8 in mpg 2 then use TMPGenc DVD Author b/c for 1 - my file is too big and 2 - sometimes it goes out of sync after the DVD is made
    Jan 2004
    Tjänare Baldrick!
    I use ffmpeggui to extract the sound from the AVI.
    It delivers in the format of .mp2 and this works well. Prehaps I should go to WAV directly? If I did would it make any diffreance do you think? TMPGenc creates a WAV anyway, but it works.
    You know the saying, If it ain't broke, don't fix it
  7. Sorry I did not mean to step on people's toes !!!
    I do hope you get your problem solved.
    I will continue to work on mine and if I come up with something useful I will pass it on.
    Good Luck
    RXH102
    Jan 2004
    No worries!
