I want to take some frames from my DVDs to use for my desktop, but my current software can't do it. I tried ALT-Print Screen and paisting into MS Paint, but that didn't work out either. Any suggestions?
The easiest way is in WinDVD or PowerDVD, assuming you have one of those already - one of them usually comes bundled with the drive. In WinDVD you hit the letter p and it will capture that frame - in PowerDVD I think there is a button right on the program interface to do it.
Other than that, I think Camtasia or Hypersnap would do it, but I'm not 100% sure.
I thought you might be able to do it with PrintScreen by turning off the video acceleration in WMP, but it didn't work for me - not sure why... -
If you have an ATI card, the bundled software will allow you to do a screen capture. You have to adjust the settings you want for your capture. But it's an easy click of a button.
Frame-By-Frame Restored James Bond Films Released
By Soopafresh in forum RestorationReplies: 9Last Post: 27th Apr 2012, 15:09 -
How do I debug/extract i-frame p-frame and b-frame?
By jwbrasil2 in forum ProgrammingReplies: 0Last Post: 20th Nov 2011, 13:24 -
Play an MTS file frame by frame, displaying timecode or frame number
By SeánB in forum Software PlayingReplies: 5Last Post: 5th Oct 2010, 17:26 -
WMP and VB6, is it possible to step forward or back frame by frame?
By gadgetguy in forum ProgrammingReplies: 11Last Post: 6th Mar 2009, 21:00 -
Advancing/Rewinding Clip Frame by Frame on Windows Movie Maker (Vista)
By ione in forum EditingReplies: 20Last Post: 9th Sep 2008, 23:53
