  1. After using DVD Decrypter, and DVD Fab to put a movie on my hard drive in the VOB IFO and BUP format I opened up Nero 6 to burn my DVD, and after opening these files in Nero and hitting the next tab, the Burning tab or button, is not active and clicking on does nothing any answers anybody, regards Graham.
  2. You did make sure that you placed the files in the VIDEO_TS folder (by double clicking on the folder to open it and THEN clicking on the "Add" button) ? Silly question but if you're using Nero ver 6 it's very easy to end up with the movie files in the root of the disc.
    Artificial intelligence is no match for natural stupidity.
  3. Did you choose the right recorder ?
  4. Originally Posted by Duchess
    Maybe it was a silly question but you sorted the problem thanks. Is`nt knowledge great!
