Does anyone know how large a file would be if I capture at 29fps, 120 minutes of video with HuffYUV default settings, 480X480 H/V resolution with a audio data rate 128Khz mono, or just full uncompressed, interlaced without HuffYUV. Is there a way to find this kind of information out?
if you set it all up in virtualdub then press F7, it will give you an estimate of how much time you can record. At a gues I'd say over 11Gb, though I can't be absolutely sure. Uncompressed is 2.1x larger than HUFFYUV, with the same quality.
I did a huff 480*480 capture yesterday for 1 hour with 44khz PCM 16bit audio and it was 18.5GB, so double that.
as for stereo and mono - there is no 128khz, but 128kbit if you encode the audio to mp3 as you capture which I would not do just to save about 500MB. either way you will need a 40GB partition.
fully uncompressed.. well, good luck. I know my PC couldn't handle the sustained writing that would require so I am unsure.
Trouble balancing quality vs size in MKV and MTS conversions.
By Omid in forum Video ConversionReplies: 4Last Post: 17th Mar 2011, 19:47 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 03:44 -
I can't reduce the size of a file using AutGK - "no fps"
By HartsVideo in forum EditingReplies: 38Last Post: 3rd Jan 2009, 23:02 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17 -
Some Questions about Conversions and File Formats...
By dadada_999 in forum Video ConversionReplies: 6Last Post: 20th Nov 2007, 22:29
